Post by bbh on Jan 6, 2018 11:19:48 GMT
Folks,
Regarding the rear axle and the large nut which holds the bearing carrier onto the axle tube - one side LH thread and the other RH thread (on later cars) - yes the one some folks mat have tightened / removed with a hammer and chisel! I can find no mention of torque setting in my workshop manual.
Does any-one have a value / reference?
Post by josefeckert on Jan 6, 2018 15:19:01 GMT
As it is a "special" 8-sided nut you need to use a special socket to remove/tighten it. I canĀ“t connect a torque wrench to my 8-sided socket, so I did it as tight as I can. I did many axles in the past and no problems so far. Its like with the Mini front axle centre nut. Roger Menadue once said: "Tighten the nut as hard as you can till the spanner breaks."
Post by bbh on Jan 6, 2018 17:40:35 GMT
Josef, I have appropriate 2 13/64ths AF Octagon socket and an adaptor which allows the drive of the torque wrench to fit... The unknown is just the torque setting.
Post by frankenhealey on Jan 6, 2018 20:02:01 GMT
Post by healeyneil on Jan 6, 2018 21:47:48 GMT
The original Churchill tool just has a 1/2" round bar to tighten the nut. It's about 18" long. How much torque can you apply with that ? - enuff !
Post by bbh on Jan 7, 2018 8:37:05 GMT
The MGAGURU site link from the above BCF thread, has the info required circa 150 lb. ft. Sq. mgaguru.com/mgtech/rearaxle/ra102.htmNow this is hugely above the 18" bar capability. It might be a moot point but getting to this limit requires an 'extension' to be fitted to the torque wrench (think cut down scaffold pole) or a rather large intake of spinach! The other problem is keeping the socket straight on what is a wide thin nut. I think I may end up with Josef's suggestion of getting as tight as I can with the longest lever I can both use whilst holding the socket tight and straight in the nut
Post by bn6 on Jan 7, 2018 16:51:48 GMT
The MGAGURU site link from the above BCF thread, has the info required circa 150 lb. ft. Sq. mgaguru.com/mgtech/rearaxle/ra102.htmNow this is hugely above the 18" bar capability. It might be a moot point but getting to this limit requires an 'extension' to be fitted to the torque wrench (think cut down scaffold pole) or a rather large intake of spinach! The other problem is keeping the socket straight on what is a wide thin nut. I think I may end up with Josef's suggestion of getting as tight as I can with the longest lever I can both use any hold the socket tight an straight in the nut I have one of those axle nut sockets that you showed earlier, there is no way on earth you will torque it to 150 lbs using that socket, you will round off the flats of the socket thats if you can keep it on the nut !!! You need a proper socket like this from DWM www.bighealey.co.uk/axle-3/socket-bn2-bj8-axle-rax235freeimagehost
Post by bbh on Jan 7, 2018 19:49:12 GMT
Well after my porridge this morning, I tightened it an much as I could with the biggest lever I had, and that will have to do. The lock washer has been folded down (nice and tight) over one of the flats, so it isn't going to be going anywhere in a hurry!.
Post by Andrew D on Feb 19, 2019 18:50:28 GMT
I've never worried about torque setting of this nut. Considering many folk have fitted it with the aid of a hammer and chisel.
I have the correct tool so I do it "nice and tight"
