Post by bbh on Aug 20, 2018 16:38:45 GMT
Anyone using an Odyssey (or similar) dry cell battery in their car?
If so any comments - good or bad?
Post by Admin on Aug 20, 2018 17:33:56 GMT
Anyone using an Odyssey (or similar) dry cell battery in their car? If so any comments - good or bad? Expensive and needs a special charger. You can use a physically smaller battery for the same cranking amps. Can be used on its side so relocating the battery for better weight distribution is easier.
Post by bbh on Aug 21, 2018 10:02:33 GMT
I thought that I could charge it / maintain it with a CTEK, I use that on my (normal) MGA battery and it works fine - sounds like I need to investigate further. Also I like the idea of a no leak option, especially with new paint.
Post by frankenhealey on Aug 21, 2018 12:52:53 GMT
I thought that I could charge it / maintain it with a CTEK, I use that on my (normal) MGA battery and it works fine - sounds like I need to investigate further. Also I like the idea of a no leak option, especially with new paint. It may be that you can use your CTEK but please check as gel batteries can be damaged by overcharging.
