Post by bbh on Aug 29, 2018 20:10:16 GMT
Just spent some time fitting one rear wing bead .... and learned what not to do! Fortunately I did manage to avoid harming the paintwork with judicious use of masking tape either side of the gap and on the tabs, but can't say I am 100% happy with the result. Think this one will have to go down as a learning exercise. Are there any tips / tricks to getting a close fit all along the seam, especially in the area just to the back of the "B" pillar where the wing starts to rise over the wheel well?
Post by healeyneil on Aug 29, 2018 21:48:51 GMT
Been a while but I seem to remember gently pushing the bead down while tightening up the wing bolts. Tricky on your own !
Post by bbh on Aug 30, 2018 19:05:05 GMT
I'll have another go at the weekend!
Post by wilburbud on Aug 30, 2018 20:42:14 GMT
When working alone, probably sandbags or lots of weight to almost hold the bead a bit too low so that when tightened fully it's pressed up that last millimeter. Don't forget the long roll of asphalt joint sealer/anti-corrosion tape and probably poke holes in that for the bolts rather than try to press them through. Lots of fun !
