Rebore
Sept 5, 2018 17:48:58 GMT
Post by dccuff on Sept 5, 2018 17:48:58 GMT
I am rebuilding a 3000 engine and the bores need rebore get but only minimal. my question is would it be an advantage to go for a maximum rebore while it's being done to increase cc and hopeful increase hp. i would like a nice fast road engine.
Rebore
Sept 5, 2018 20:17:15 GMT
Post by bbh on Sept 5, 2018 20:17:15 GMT
Couple of thoughts: * Consider this in relation to what else you are planning to do with the engine and whether all of the changes work well together. * Decide on what pistons you want to use - they may be only available in certain sizes. * (Yes I know more than a couple !!) but if you go to the max and something unplanned happens, it leaves you with little scope for recovery - well without major work. The following may be of interest : www.ntahc.org/techtips-03/
Rebore
Sept 6, 2018 14:20:41 GMT
Post by Admin on Sept 6, 2018 14:20:41 GMT
bbh has it in a nutshell. Never go to max re-bore just in case you trash the engine later and find yourself with nothing left but a coffee table support.
