Post by dougie on Dec 19, 2018 2:03:06 GMT
I love the looks of DP 1769, Cape did a great job on it.
Post by bbh on Dec 19, 2018 20:01:45 GMT
Agreed.
Post by bn6 on Dec 19, 2018 23:31:27 GMT
Cape did some work on my car and I also agree they do a good job.
Post by bbh on Dec 21, 2018 10:03:28 GMT
from a different angle .....
Looks good, although that copper water pipe does stick out a bit, personally I would have done it in stainless. Off on another tangent, and linking to another thread on here re Filter Kings, it is interesting to see where the unit has been placed on this car, just in front of the LH footwell, with a protective / heat barrier between it and the Rear most carb. It limits access a little, but I guess it might be a bit cooler down there by the wing vent?
Post by dougie on Dec 22, 2018 2:11:03 GMT
That seems a funny placement position. I have my pressure regulator/gauge in the front left area, still out of the heat. Fuel filters in the rear, placed after the fuel pump.
Post by bbh on Jan 1, 2019 21:01:14 GMT
Webers had crossed my mind as well but as you say if you wanted the best out of the engine you would end up with not a very practical road car. I have gone for the DWR8 cam with valve pockets, balanced crank line and lightened flywheel, for the period look correct RHD Ruddspeed manifolds with triple carb setup, DWR tubular exhaust. Once I have recovered financially I am hoping for a DWR fast road alloy head You mean something like this..... Dougie, Who's hose clamps are you using?
Post by dougie on Jan 2, 2019 1:24:39 GMT
Post by bbh on Jan 2, 2019 9:19:19 GMT
