ivan
New Member
Post by ivan on Apr 10, 2019 10:31:51 GMT
Hello all, I am trying to complete my 2.4 liter engine which has had no valve seals. I am wandering if it would be a good idea to install valve seals. Maybe at least on the intake valves. Any opinions? Gratefully Ivan
Post by frankenhealey on Apr 11, 2019 14:58:27 GMT
Hi Ivan,
AH Spares sell these with the following descritions
PART NO: ENG735C PRODUCT NAME: OIL SEAL-valve stem-modified DESCRIPTION: These valve oil seals are far superior to the original design to prevent oil leaking into the cylinders. With a metal body they are a press fit on to the valve guide so they will not come loose compared to other cheap alternatives.
A must for performance or standard engines that are fitted with single or double valve springs.
ivan
New Member
Post by ivan on Apr 12, 2019 7:38:58 GMT
Thanks frankenhealey,I should have been more clear as to which engine. The engine is 2.5 liter ( not 2.4 as I stated in the original post) belonging to a 1948 Healey Duncan. My concern really is will there be enough lubrication to the valves with the seals being introduced? Ivan
Post by frankenhealey on Apr 12, 2019 20:46:19 GMT
Thanks frankenhealey,I should have been more clear as to which engine. The engine is 2.5 liter ( not 2.4 as I stated in the original post) belonging to a 1948 Healey Duncan. My concern really is will there be enough lubrication to the valves with the seals being introduced? Ivan Hi Ivan, We have a member on here woodworm who IIRC is 'real' Healey guy, not the fake Austin Healeys that most have . I suggest you PM him on here.
ivan
New Member
Post by ivan on Apr 22, 2019 21:01:53 GMT
Mr frankenhealey I have had no luck contacting woodworm, have you any other means to get in touch Ivan
Post by frankenhealey on Apr 24, 2019 14:19:24 GMT
Mr frankenhealey I have had no luck contacting woodworm, have you any other means to get in touch Ivan Sorry, I haven't but he's on here every couple of weeks so might pick it up yet. Alternatively if it's Riley unit we're talking about how about trying one of their specialists?
