Post by austinrod on May 6, 2019 16:56:47 GMT
Hello enthusiast AH fan ! I am Rod and I am starting to restore one AH BT7 1960. Currently I am working on frame by changing rusty parts. I purschased some parts on Ahspares. Regards,
Post by frankenhealey on May 6, 2019 19:43:17 GMT
Hello enthusiast AH fan ! I am Rod and I am starting to restore one AH BT7 1960. Currently I am working on frame by changing rusty parts. I purschased some parts on Ahspares. Regards, Good luck with your build and please keep us updated.
Post by dougie on May 7, 2019 3:39:21 GMT
Looks like a nice project. Plans for the engine?.......
Post by austinrod on May 8, 2019 17:45:23 GMT
Hello enthusiast AH fan ! I am Rod and I am starting to restore one AH BT7 1960. Currently I am working on frame by changing rusty parts. I purschased some parts on Ahspares. Regards, Good luck with your build and please keep us updated. Thank you, I will try
Post by austinrod on May 8, 2019 17:48:23 GMT
Looks like a nice project. Plans for the engine?....... Yep lot of work to do .. , I would like to perform some changing but not like you Dougie , I plan to add EFI system without to keep original SU, I will build a new intake manifold.
Post by bbh on May 8, 2019 19:19:53 GMT
There are quite a few approaches to EFI on a Healey out there, but this is my favourite ....
Interestingly Steve, having sold this car is doing another and taking a slightly different route to the EFI installation.
Post by austinrod on May 8, 2019 20:22:49 GMT
There are quite a few approaches to EFI on a Healey out there, but this is my favourite .... Interestingly Steve, having sold this car is doing another and taking a slightly different route to the EFI installation. Yes, I already spoke with Steve about his older red car. His approach was interessting because he kept the original design, EFI integration was quite discreet on engin compartment, but litte bit more fully under rear seat with electonik parts . The new one study is more modern, intake manifold replace SU carburetors and Megasquirt is used as ECU. First of all, I will try to build my own intake manifold, this part is harder, most important than the other steps to build EFI setup. Here is a link with EFI made by NL guy. For me the main difference between Steve and NL guy is ignition. Steve use a legacy distributor with ECU connection while NL guy use modern ignition coil
Post by austinrod on May 11, 2019 10:08:14 GMT
Post by austinrod on May 13, 2019 21:02:30 GMT
Nobody have an idea about my clutch ?
Post by frankenhealey on May 14, 2019 13:53:27 GMT
Nobody have an idea about my clutch ? The little rebuilt sticker might give you some clues
Post by austinrod on May 14, 2019 17:00:30 GMT
Nobody have an idea about my clutch ? The little rebuilt sticker might give you some clues I know what rebuilt mean , I asked more about yellow springs ?
Post by bbh on May 14, 2019 20:27:16 GMT
Someone know if yellow springs have a specific pressure or dedicated for road or race .. or something like that ?
Undoubtedly yes, but without knowing the manufacturer and looking up their comparison table, it would be guess work. As Mr FH said, that little sticker might give a clue, I can make out the Beck bit but not the first word(s)
Post by austinrod on May 15, 2019 6:36:07 GMT
Someone know if yellow springs have a specific pressure or dedicated for road or race .. or something like that ? Undoubtedly yes, but without knowing the manufacturer and looking up their comparison table, it would be guess work. As Mr FH said, that little sticker might give a clue, I can make out the Beck bit but not the first word(s) The brand is beckarnley, I tried to find some informations on their website but nothing really interesting www.beckarnley.com/
Post by bbh on May 15, 2019 20:42:20 GMT
Post by austinrod on May 16, 2019 19:35:45 GMT
TY, I will check out One rear brake plate anchor is damaged, I didn't find spare parts on website except on limora. Someone knows if I am able to find only the center ring of brake plate anchor (it is unsolder) or if someone sell a second hand part ?
