Post by bbh on Feb 1, 2020 20:07:28 GMT
Any recommendations for upgraded air filters to fit a tri-carb set-up? In my case triple HS6's.
Post by healeyneil on Feb 6, 2020 22:56:50 GMT
Probably not much help to you, but I used sock type foam filters ( not old socks ! ) over long ram pipes, first over triple HD8s then triple HD6s. Not a particularly elegant solution
Post by bbh on Feb 8, 2020 20:01:21 GMT
Probably not much help to you, but I used sock type foam filters ( not old socks ! ) over long ram pipes, first over triple HD8s then triple HD6s. Not a particularly elegant solution If you were to do it again, what would you use? I have seen "bolt on" versions from K&N (both pancake & cone), RamFlo and Pipercross. K&N, seem to use a paper element and the other two a foam filter.
Post by dougie on Feb 9, 2020 3:21:05 GMT
Any recommendations for upgraded air filters to fit a tri-carb set-up? In my case triple HS6's. Contact Steve Thomton, he developed a rally replica utilizing an EFI system based of triple SU's. Steve's a great guy, very helpful. He's working on a new EFI 6-cylinder now. "scthomton@yahoo.com" <scthomton@yahoo.com>
Post by bbh on Feb 9, 2020 19:22:12 GMT
Dougie, many thanks, I'll follow-up with Steve.
