Post by stevebenno47 on Mar 3, 2023 8:23:29 GMT
Can anyone help how I can improve or fix a leak coming from the overdrive - see attached photo? Do I need to take the overdrive apart or is there a 'simple' solution? Many thanks
Post by healeyneil on Mar 4, 2023 10:53:11 GMT
Assuming it’s coming from the overdrive/gearbox joint, I would try cleaning the area thoroughly, and putting a little rev sealant over the area. It’s a bit of a bodge, but if it saves taking the gearbox out and taking the overdrive off, it’s worth a try. I’m assuming two things here though One, that the nuts holding the two parts together are tight, and two, that it’s not a massive oil leak
