Post by dccuff on Jan 7, 2019 12:57:23 GMT
1 x 6 Cylinder Cam Camshaft Taken From 2.9 Westminster engine VGC Would Be Good To Use As Is Or For A Re-Profile Exchange. DW Exchange Price £295, Buy Outright £595
1 x Austin Healey 6 Cylinder Block Removed From My 100/6 Healey. 26D Engine No. It Was All Water/Oil Tight When I Took It Apart. Left It Uncleaned So It Can Be Seen That There Are No Leaks On Cylinder Head Face And Core Plugs. All Bearing And Piston Surfaces All Look Good .
1 Timing Cover For 6 Cylinder Big Healey
1 Set (12) Cam Follows No Wear I Can See
Set Main bearing Caps x 4
1 Set Exhaust Manifold 8 Port Head
1 Set Exhaust Manifold 12 Port Head
4 Lucas Dynamo – Not Including Coil Bracket
1 Lucas Start Motor M418G 12V
1 Intake Manifold For 1¾”SU
1 Set Rocker Gear Have Push Rod In Separate Listing
1 Set Carbs H4 1½” SU AUC 6020 Body, 1208 Float Body With Linkage
1 Set Carbs HD6 SU 1¾” Complete Body AUC1346 & 8490 Float AUC 1310
1 Set 6 Conrods And Pistons Complete Set Of Numbers With Bolts. Pistons May Need Replacing But A Perfect Set Of Conrods And Bolts
1 8 Port 6 Cylinder Head. Complete With Valves And Springs. Good Condition. No Sign Of Any Leaks Or Cracks.
Can send photos if required.
Dave 07866678840
![*](//storage.proboards.com/forum/images/stars/star.png)
Post by bn6 on Apr 17, 2019 19:11:07 GMT
Dave you have a PM and also a text message to the number given.
