Post by dougie on May 20, 2019 3:44:26 GMT
Austinrod -
Where are you located? I might be able to find a source for parts for you, if you're in the states. If in the UK or Europe, shipping costs might be too high.
Post by austinrod on May 20, 2019 10:18:26 GMT
Austinrod - Where are you located? I might be able to find a source for parts for you, if you're in the states. If in the UK or Europe, shipping costs might be too high. I am located in France, so shipping costs is the same price as the item itself
Post by austinrod on May 21, 2019 18:58:32 GMT
BT7 is back at home ! ![](https://i.ibb.co/GRrg3DK/IMG-20190521-083506.jpg)
Post by austinrod on May 25, 2019 17:14:31 GMT
Do you know how can I remove srew insert on wishbone arm ? Do I need to remove cotter pin ? Does a seal is present between wishbone arm and screw because I have to send to sand blaster + epoxy ( cook at 200° seal not resist to heat) ? Thank you for your help ! ![](https://i.ibb.co/30zjfXd/IMG-20190525-155341-6.jpg) ![](https://i.ibb.co/vkjvSzH/IMG-20190525-155353-5.jpg)
Post by bbh on May 25, 2019 20:28:14 GMT
Post by austinrod on May 26, 2019 6:49:08 GMT
Ok, thank you, it's done ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by austinrod on Jun 9, 2019 17:06:31 GMT
Hello ! Finaly found my rear plate anchor at AHspares in second hands. I also ordered from them the begining of my spares list. I started mounting some items on car. Few pictures of progression ![](https://i.ibb.co/86DL615/IMG-20190601-192601-0.jpg)
Almost 2 hours to clean engin with Kartcher warm water ![](https://i.ibb.co/gRxkRzv/IMG-20190607-143058-3.jpg)
![](https://i.ibb.co/VBrRVCw/IMG-20190607-120820-2-copie.jpg) ![](https://i.ibb.co/L57kZyM/IMG-20190609-180519-6.jpg) ![](https://i.ibb.co/fvdyYr0/IMG-20190609-180603-8.jpg)
Post by bbh on Jun 9, 2019 19:33:24 GMT
Progress.... Re front suspension, before you tighten anything, remember to put a 2" spacer (block of wood will do, between the shock bump and the base plate to get the settings right. ![](https://i.ibb.co/Z6JCvbz/IMG-1076.jpg)
Post by dougie on Jun 10, 2019 3:10:26 GMT
Looking good!
Post by austinrod on Jun 10, 2019 9:33:49 GMT
Progress.... Re front suspension, before you tighten anything, remember to put a 2" spacer (block of wood will do, between the shock bump and the base plate to get the settings right. ![](https://i.ibb.co/Z6JCvbz/IMG-1076.jpg) Thank you for trick ! Does with this block of wood you can fit without any issue your both Spax supports + absorber ? because for me I am not able to fit my absorber when I put 2" block. Do I need fit Spax when I remove block of wood (in this case Armstrong lever shock going down little bit I guess) ?
Post by austinrod on Jun 13, 2019 22:00:52 GMT
Reply to myself, wood block needs to be stay in place till I will put the car on the floor, then I will mount Spax.
Post by austinrod on Jun 14, 2019 14:16:21 GMT
Can someone help me to find the right way to fit bearing and washers I checked BHH picture but I am not able to know how to fit bearing
This way ![](https://i.ibb.co/DK5Qb12/1.jpg)
or this way
![](https://i.ibb.co/ZSBq2Lq/2.jpg)
Does the washer are behind the bearing like the picture ?
Thank you
Post by bbh on Jun 15, 2019 19:09:14 GMT
1st photo, see below: ![](https://i.ibb.co/Hx1kYr8/IMG-20190615-0001.jpg)
Post by austinrod on Jun 16, 2019 6:18:34 GMT
1st photo, see below: ![](https://i.ibb.co/Hx1kYr8/IMG-20190615-0001.jpg) Thank you !
Post by austinrod on Mar 1, 2020 9:29:20 GMT
