Post by bbh on Jan 26, 2021 19:35:35 GMT
Post by healeyneil on Jan 26, 2021 22:17:19 GMT
I wonder if they've been cobbled together. The fuel lines don't make sense for a start
Post by dougie on Feb 1, 2021 6:18:42 GMT
WOW - they're pretty proud of those parts that will still need a full rebuild. That style of the Ruddspeed manifold usually can only be used with the stock exhaust manifolds due to the lower mounted balance tubes. I sourced the alternative version with an upper mounted balance tube years ago which allows me to runa free-flowing racing style header system for max HP.
Post by bn6 on Feb 5, 2021 23:52:43 GMT
Dougie, I believe the set you have above were also made for left hand drive cars to clear the steering column.
