wyn
New Member
Post by wyn on May 20, 2024 11:18:28 GMT
I have a Healey 3000 BJ8 with some overdrive problems. When I flick the dash switch, it engages overdrive OK. When I turn off the overdrive, it will not come out of overdrive. I have found that if I switch the ignition off, then overdrive will disengage. Not the ideal way of using overdrive!! Car back in the garage, I turn the ignition on and then turn on the o/d swich and I hear the click of the solenoid. I turn off the switch and no solenoid click. I turn off the ignition and I hear the solenoid clicking. I have little auto electrical knowledge and I'm wondering if I have a dash swich failiure, a throttle switch failiure, relay or anything else (possibly an earthing problem)
Any advice or guidance would be appreciated. Thanks.
wyn
New Member
Post by wyn on May 20, 2024 13:50:41 GMT
Problem now solved. Thanks
Post by bbh on May 21, 2024 18:31:07 GMT
Out of interest, what was the solution?
