mikej
Post by mikej on Sept 19, 2017 18:53:02 GMT
Getting ready for final stages of paint and i have a question??
Where the Tenax studs fit to the rear shroud on a BJ8 should they just bolt through the shroud or into a rivnut?
Post by frankenhealey on Sept 19, 2017 21:19:01 GMT
The last studs I fitted were bolted.
mikej
Post by mikej on Sept 20, 2017 16:32:30 GMT
Cheers Ian,
I did ask on the facebook group and had mixed answers.
I suspect the answer is not originally but as they worked loose and elongated the hole, rivnuts were used.
PS do you use another name on face book?
Post by Admin on Sept 21, 2017 9:16:59 GMT
Cheers Ian, I did ask on the facebook group and had mixed answers. I suspect the answer is not originally but as they worked loose and elongated the hole, rivnuts were used. PS do you use another name on face book? Yes, after a leedle bit of identity theft I am a person of many names on t'internet.
