Post by josefeckert on Oct 15, 2017 17:20:30 GMT
Its just corrosion. When you look on the cylinder head you will find these holes in the head. These go into the water channel. They decided for whatever reason not to drill them through into the block. They are not needed. These kind of things you see also on other blocks like on the A-Series engines. Just ignore them. There is no need to do anything.
Post by josefeckert on Oct 15, 2017 18:24:06 GMT
Just leave it as it is. When its leaking its going into the water channel. No problem at all.
Post by bn6 on Oct 15, 2017 18:41:06 GMT
Just leave it as it is. When its leaking its going into the water channel. No problem at all. Thanks for the information josefectert not seen it before until now.
